Voucher
Dendevries
Paid with a voucher and it says  suspended still why is that
11 REPLIES 11
OP already indicated payment isn't showing.   Suggested they input the voucher again.   Failing that, contact CSA's for help.
They replied "No".
The 'incognito/private' tab may display differing results - hope they try and report back.
@Dendevries   just want to confirm you logged in using Incognito  mode?
confirm the account status
Check Avaliable fund to see if it shows $50
And check Payment history to confirm if PM took the money.
and if you don't see anything in payment history about the voucher, maybe try to load the voucher again
if nothing work and if you have not done so, open ticket with PM support as advised by @HALIMACS
Dendevries
No
OK @Dendevries , so if it's showing as not having been applied, then try to input the voucher again.
Some vouchers have 'waiting' periods before they become able to be fulfilled on an account.
Failing that, contact a Customer Support Agent to have them apply it for you:
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
Dendevries
Itsays I' didn't pay it I have had nothing bit problems the last 2 months with public mobile I need this fixed I'm really considering going elsewhere
@Dendevries
In the self-serve Payment tab, do you see the voucher payment itemized there?
Or is the payment amount resting in your Available Funds balance?
Try this:   Log into self serve, place your account in Lost/Stolen mode.   Log out.  Then log back in and remove the Lost/Stolen mode designation to see if that gets things up and running.
Dendevries
Nothing is working
Dendevries
I paid through my account ID did that yesterday I have rebooted my pg9ne and it still says suspender
OK @Dendevries , the account still says "suspended", but did you TRY the device to see if it can call or text or use mobile data?
Some of the time folks see erroneous messaging on the self-serve screen even after they've done something they know was done correctly.
Do none of your services work?
Try tapping this area:
Dendevries
I did this yesterday  and it's still suspended I have rebooted it and nothing my account still says suspended I put a 50 dollar voucher on it says I didn't
@Dendevries   did you pay via *611 or pay on My Account?
If you paid via My Account, try to login My Account again using Incognito mode and check the status again
If you paid by *611, wait 15 minutes, reboot and check again.  If it still does not work , try to pay again by My Account
