Voucher
03-14-2021 11:05 AM - edited 01-06-2022 02:18 AM
I entered a voucher about 45 minutes ago and the phone doesn't work and it says I am not due to pay now till April, how long does it take?
Payment
03-14-2021 11:48 AM
@LMaxheleau : Just in case...just adding money doesn't do anything unless you were suspended.
03-14-2021 11:40 AM
May be you can wait for more time, as "Good things come to those who wait.. "
03-14-2021 11:28 AM
Did you use self-serve or *611 to apply the voucher?
Using your phone, dial *611:
- Press 1 from the main menu.
- Press 1 to select payment via voucher.
- Enter the 12 digit pin from your payment voucher. The location of the PIN varies depending on where you purchase your voucher; however, you will typically find it on the top or the bottom of your receipt. Below is an example, so you know what to look for:
If it doesn't work after restarting your phone, log into your self serve account and confirm your account status and whether there is any available balance displaying.
If it is showing "active" and the voucher was applied (look in transaction history to confirm) and there's no "reactivate" option to select, AND you still have no service, contact moderators to inquire.
To contact a moderator, there are 2 methods:
- Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now. Follow the prompts to submit a ticket, or,
- Send a private message to the moderator by clicking here You’ll need to be logged into your Community account for the link to work.
03-14-2021 11:15 AM
When did you purchase the voucher ? It can take a few hours to be activated.
03-14-2021 11:07 AM
@LMaxheleau : What happens when you dial 611? Maybe restart the phone. Log in and check your self-serve for Active status and Available Funds.
