Voucher
ghamblen
Why doesn't Public Mobile accept my voucher # xxxxxxxxxxxxxxxxxxxx which I purchase today from Telus  for $15.00?
edited by computergeek541: removed voucher number
10 REPLIES 10
RosieR
Hi @ghamblen it could be that you are entering the wrong 12 digit number... use the PIN#
If you are using your self serve account to upload your voucher, log out.  Before you log in again, delete your browsing history, cache and cookies.  Log back in.  Upload your voucher again using the PIN#.  Reboot.
You can also dial 611 and upload your voucher there using the voucher's PIN#
I hope this helps
RosieR
HALIMACS
@computergeek541
Voucher# needs wiping from initial post.
 @HALIMACS : We've all been there at least once. 🙂
@Anonymous wrote:
 @HALIMACS : Um..yeah...then edit your quote. 🙂
@Anonymous   ya got me!!! 🙄
I was on it.  Somewhat intended it to display as it now does.    Thx.
HALIMACS
@ghamblen wrote:
Why doesn't Public Mobile accept my voucher # xxxxxxxxxxxx which I purchase today from Telus  for $15.00?
@ghamblen
Edit out this number immediately.  Click 3 little dots from your post and clear the number shown in red
Anyone can see what you've posted, this is a PUBLIC FORUM -  i hope someone else hasn't tried to use.
You may be out of luck already.
Staliger
@ghamblen It takes time for voucher to be activated. A few hours around. Also, I recommend to remove the number for privacy reasons.
TheGx
@ghamblen :This forum can be viewed by anyone including anyone wanting to use your voucher, now that you've posted your voucher PIN, others might have used it before you have chance to use it.
 @ghamblen : You just laid out free money for some nefarious fellow customer to snatch up. Did you try the 611 service? Is that the only 12 digit set of numbers on the voucher? If more than one then use the one called PIN.
Edit: wait...a Telus voucher is only good for Telus...not here. I know both are owned by Telus but you need a Public Mobile voucher.
Triguy
It can take a few hours for it to be activated.
You should remove the voucher# by clicking on the three dots on the top right.
