Voicemal
dan23
Hi everyone I want to ask you what's the phone number of the voicemail in Ontario for public mobile I deleted it somehow
Thank you
gpixel
@dan23
Dial ##21# then ##004# to reset the number to default
then Dial and hold '1' to access your voicemail
 @dan23 : It should be the same as the call forwarding options in your dialer too (assuming you haven't touched those from default initial activation).
set up voicemail?  Here's how:
  1. Hold down the ‘1’ key on your phone keypad to dial your voicemail access number. Calling your own 10-digit phone number will also bring you to your voicemail.
  2. When prompted, enter a password between 4 to 15 digits long. Try to make it hard to guess, but easy to remember. It will be more secure if you avoid using numbers that are repetitive or sequential such as ‘1111’ or ‘1234’.
  3. Choose whether you want to bypass your password when calling from your own phone.
  4. Record your name, and a personalized greeting.
  5. When you’re done, hang up to end the call.
Below are the various voicemail access numbers:
Access NumProvinceCNAC Rate CentreIntended Serving Area?
403-371-6245AlbertaCalgarySouthern AB 403/587/825
(Old Mike #)
587-580-4001AlbertaCalgarySouthern AB 403/587/825
587-580-4002AlbertaCalgarySouthern AB 403/587/826
587-580-4003AlbertaCalgarySouthern AB 403/587/827
587-580-4004AlbertaCalgarySouthern AB 403/587/827
587-580-4005AlbertaCalgarySouthern AB 403/587/827
587-580-4006AlbertaCalgarySouthern AB 403/587/827
587-580-4007AlbertaCalgarySouthern AB 403/587/827
587-588-4001AlbertaEdmontonNorthern AB 587/780/825
587-588-4002AlbertaEdmontonNorthern AB 587/780/825
778-580-4001BCWhalleyoutside greater Vancouver area
778-580-4002BCWhalleygreater Vancouver area
778-580-4003BCWhalleyOutside greater Vancouver area
778-581-4001BCWhalleyBC 250
778-581-4002BCWhalleyBC 250
204-588-4001ManitobaWinnipegWinnipeg 204/431
204-588-4002ManitobaWinnipegOutside of Winnipeg 204/431
506-588-4001New BrunswickMonctonNB 428/506
902-580-4001Nova ScotiaHalifaxNS/PEI 782/902, NL709/879
867-688-4001NWTYellowknifeNWT/NU/YT
705-780-4001OntarioBarrieON 249/705
289-680-4001OntarioHamiltonON 289/365/905
226-580-4001OntarioLondonON 226/519/548
613-581-4001OntarioOttawa-HullON 343/613
647-580-4001OntarioTorontoON 416/437/647
647-580-4002OntarioTorontoON 416/437/647
647-580-4003OntarioTorontoON 416/437/647
647-580-4004OntarioTorontoON 416/437/647
647-580-4005OntarioTorontoON 416/437/647
647-580-4006OntarioTorontoON 416/437/647
647-580-4007OntarioTorontoON 416/437/647
450-320-4001QuebecGranbyOutside Montreal 450/579
438-580-4001QuebecMontrealMontreal 438/514
581-580-4001QuebecQuebec City367/418/581
819-588-4001QuebecSherbrookeQC 819/873
306-580-4001SaskatchewanReginaSouthern SK 306/639, Edmonton
306-580-4002SaskatchewanReginaNorthern SK 306/639
Good Luck
