Can't receive incoming calls, straight to voicemail
dan_d
Hello, I just recently switched to Public from FM 6 days ago, the service has been great however when my friend attempted to call me today, it went straight to voicemal. I then called myself from my home phone and got the same issue.
Everything else is working fine:
Data is working great
Can make outgoing calls
Can send/recieve text
Things I've tried:
1) Restarting the phone
2) Reinserting the SIM card
Anyone have any advice as to what the problem is, I have an iPhone 7. @Mary_M?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Luddite
Check the phone settings in case you have accidentally turned on block calls, or do not disturb. Those are usually the culprits.
Then login to voicemail confirm that is also not set to send to voicemail.
Luddite
dan_d
Not sure what did it, as I checked and calls were not blocked but it seems that incoming calls now come through! Tried calling myself from 2 different phones and both worked
@dan_d Must be special voodoo magic that you have! 👺
PBForMe
Interestingly enough after 1 year on PM with no voice issues I had the exact same thing today, person tried calling me twice went straight to voicemail. Looked at my phone, was connected fine... no reported missed calls.
Tried calling myself and the same thing happened, no ring straight to voicemail. On my phone I went to access my voicemail, then I received all the voicemail notifications of my missed calls and after that my calls were going through again.
TL;DR Same problem today, accessing voicemail on phone somehow fixed it.. or just happy coincidence.
