03-31-2023 09:27 PM - last edited on 04-01-2023 01:24 AM by computergeek541
I want to be able to see my voicemails on the app but when I open the app it says “call voicemail”. I restarted the network but still doesn’t work. So how can I fix this problem.
03-31-2023 10:05 PM - edited 03-31-2023 10:06 PM
@Thamir you meant you want to delete your name recording in the voicemail greeting?
once the name recording is deleted, your voicemail greeting will change back to the standard greeting.: you have reached mailbox no. xxxx.
03-31-2023 09:35 PM - last edited on 04-01-2023 01:22 AM by computergeek541
How can I delete my voicemail greeting. I recorded by mistake. I know how to re-record but I don’t want to have greeting on my voicemail. Can anyone give me some suggestions how to do that?
03-31-2023 09:28 PM
