Voicemail
Pilog75
How do i deactivate voicemail?
@Pilog75 wrote:
Thanks but its not workihg...
@Pilog75   um..what is not working?
many have been using this trick to let the phone rings forever and hence people cannot leave message
there is another trick for extended absense and dissalow people to leave message
(https://www.publicmobile.ca/en/bc/get-help/articles/add-an-extended-absence-greeting)
To set extended absence
dial into your voicemail and log in with your PIN.
In the main menu, press 3 (manage greetings),
then 4 (manage extended absence greeting),
then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
Then press 4 to turn on extended absence
Finally, press 5 to dissallow anyone to leave you a message.
To receive  messages again:
then 4 to turn off your extended absence greeting
After doing this, your previous personal greeting goes back into effect automatically, and callers can leave you messages again.
Pilog75
@Pilog75   you cannot really deactivated voiemail, but we have workaround to "disable" it
To "disable" voicemail, dial: *004*8080000000# on your phone
Then all calls will ring forever or get a fast busy tone instead of forwarded to the voicemail.
To reset it back to defaults, dial ##004#
