04-24-2021 10:10 PM - edited 01-06-2022 01:53 AM
04-26-2021 01:58 PM
@Mashlee I'm not sure if you clarified whether you were unable to access to your voicemail because you were out of outgoing mins or not. Anyway, thought I would just add that you could also have just purchased the $5/500 Canada wide mins to supplement the $15 as back up mins if you did run out of mins instead of upgrading plans, especially since domestic add-ons don't expire but will be available when needed, i.e., when you're out of plan mins before the renewal cycle resets everything.
04-25-2021 09:15 AM
@Mashlee wrote:Hello everyone,
I upgraded from a 15 dollar plan to 25 so I can access my voicemail. I have attempted all the remedies stated on this forum, and I still do not hear access to my voicemail. Helppppppp. I am so frustrated with this phone company.
@Mashlee - you need to choose to "Change Plan Now" if you want to upgrade your plan before your current plan is due to renew.
But in order to successfully do this you need to add sufficient funds to your account first, then choose "Change Plan Now".
NOTE: any amount paid from your $15 is not returned to you or prorated!
So, therefore, it is usually recommended to choose "Change on next renewal date".
If the only reason to upgrade your plan right away was to check your voicemail, then simply call your number from a device that is NOT your Public Mobile dialer, a landline OR use a wifi calling app (like FONGO = free to use) to call your number to check your messages.
You voicemail PIN will be required to access your messages.
FYI - Voicemail Access Numbers:
04-25-2021 07:45 AM - edited 04-25-2021 09:22 AM
On your self-serve account, what does your "My Plan" display? Is it like below?:
If so, you have unlimited outgoing minutes.
Now, did you set up voicemail? Here's how:
Access Num | Province | CNAC Rate Centre | Intended Serving Area? |
403-371-6245 | Alberta | Calgary | Southern AB 403/587/825 (Old Mike #) |
587-580-4001 | Alberta | Calgary | Southern AB 403/587/825 |
587-580-4002 | Alberta | Calgary | Southern AB 403/587/826 |
587-580-4003 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4004 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4005 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4006 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4007 | Alberta | Calgary | Southern AB 403/587/827 |
587-588-4001 | Alberta | Edmonton | Northern AB 587/780/825 |
587-588-4002 | Alberta | Edmonton | Northern AB 587/780/825 |
778-580-4001 | BC | Whalley | outside greater Vancouver area |
778-580-4002 | BC | Whalley | greater Vancouver area |
778-580-4003 | BC | Whalley | Outside greater Vancouver area |
778-581-4001 | BC | Whalley | BC 250 |
778-581-4002 | BC | Whalley | BC 250 |
204-588-4001 | Manitoba | Winnipeg | Winnipeg 204/431 |
204-588-4002 | Manitoba | Winnipeg | Outside of Winnipeg 204/431 |
506-588-4001 | New Brunswick | Moncton | NB 428/506 |
902-580-4001 | Nova Scotia | Halifax | NS/PEI 782/902, NL709/879 |
867-688-4001 | NWT | Yellowknife | NWT/NU/YT |
705-780-4001 | Ontario | Barrie | ON 249/705 |
289-680-4001 | Ontario | Hamilton | ON 289/365/905 |
226-580-4001 | Ontario | London | ON 226/519/548 |
613-581-4001 | Ontario | Ottawa-Hull | ON 343/613 |
647-580-4001 | Ontario | Toronto | ON 416/437/647 |
647-580-4002 | Ontario | Toronto | ON 416/437/647 |
647-580-4003 | Ontario | Toronto | ON 416/437/647 |
647-580-4004 | Ontario | Toronto | ON 416/437/647 |
647-580-4005 | Ontario | Toronto | ON 416/437/647 |
647-580-4006 | Ontario | Toronto | ON 416/437/647 |
647-580-4007 | Ontario | Toronto | ON 416/437/647 |
450-320-4001 | Quebec | Granby | Outside Montreal 450/579 |
438-580-4001 | Quebec | Montreal | Montreal 438/514 |
581-580-4001 | Quebec | Quebec City | 367/418/581 |
819-588-4001 | Quebec | Sherbrooke | QC 819/873 |
306-580-4001 | Saskatchewan | Regina | Southern SK 306/639, Edmonton |
306-580-4002 | Saskatchewan | Regina | Northern SK 306/639 |
04-24-2021 10:29 PM - edited 04-24-2021 10:33 PM
04-24-2021 10:26 PM
Yes, I paid for three months in advance.
When I use the above-said number I receive the same male voice air message.
04-24-2021 10:19 PM
You can also dial vm number from any landline and enter your phone number and code to access it remotely.
04-24-2021 10:18 PM
@Mashlee wrote:I upgraded from a 15 dollar plan to 25 so I can access my voicemail. I have attempted all the remedies stated on this forum, and I still do not hear access to my voicemail. Helppppppp. I am so frustrated with this phone company.
I'm assuming that you changed plans because you were out of outgoing minutes but thought that changing plans would allow you to access your voicemail box? If you call your own number, do you have access? If you do, this is likely an issue with the correct vociemail retrieval number not being programmed correctly into your call forwarding settings.
04-24-2021 10:18 PM
You have access to your voicemail with 15 plan just like any other plan.
If nothing happens when you call your voicemail you should go into your forwarding settings and erase all the entries let the system fill it in with the vm number
04-24-2021 10:16 PM
@Mashlee : If you were on the $15 plan then perhaps you had used all your minutes. Are you sure you successfully upgraded to the $25 plan?
What happens if you dial 17785804001?
What happens when you press and hold 1 on your dialer?
