Voicemail
11-22-2019 03:25 PM - edited 01-05-2022 08:05 AM
How do I get notified when I have a voicemail? My voicemail button doesn't change colors to notify me. Is this somethin gPM doesn't offer?
Joining Public
11-25-2019 02:35 PM
I have an Iphone 8. Since switching over to PM I have no way of knowing if I have a voicemail unless I call my number and I'm told I have a new VM.
11-22-2019 03:59 PM
@alritor wrote:How do I get notified when I have a voicemail? My voicemail button doesn't change colors to notify me. Is this somethin gPM doesn't offer?
If you are using an iPhone and had visual voicemail enabled with your previous provider then that's a problem.
11-22-2019 03:59 PM - edited 11-22-2019 03:59 PM
Voicemail button? it's an on-screen noficiation. When there's no message, the icon is gone. When there's a message,it will show. Some phones have a flashing light.
11-22-2019 03:37 PM
It is your phone probably
Check the settings as well as voicemail and notification settings. I'm not sure which authorizations are needed too.
11-22-2019 03:28 PM
@alritor, what phone are you using? Your phone dialer app should provide notifications for activities such as missed calls and voice messages.
