04-12-2019 01:29 PM - edited 01-05-2022 04:19 AM
Hi,
Is voicemail included in my plan?
I have a 3 month $165 US long distance with 6 GB of data?
04-12-2019 01:50 PM
@ZfromVanC wrote:Yes, you can follow these steps to set up Voicemail:
There's a trick to not use the handset for initial set up. Reset voicemail password in the self-serve. It resets back to the phone number. Call the number from another phone and it'll start the set up and use the password.
04-12-2019 01:31 PM
