10-28-2023 08:56 PM
I tried some links person one on one tech support gave me to try to get my voicemail to answer after 4 rings instead of 10 but nothing worked. Now I can't get my voice mail to come on at all.
10-28-2023 09:18 PM
HI @Phil123123
are you on iPhone? I am not sure if the new Live Voicemail feature will help in your situation.
10-28-2023 09:02 PM - edited 10-28-2023 09:02 PM
there used to be trick to change the number of rings before voicemail, but that is based on Conditional forwarding, which currently does not work due to some system glitch
If your phone is one of those using VoLTE, you can try to ask support to fix the conditional forwarding first, we heard it is possible, but not 100% certain. Open the ticket with PM support here:
If it is fixed you can then use this trick to change the number of rings before voicemail
Dial this sequence: *61 *16475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
For one ring, enter 5.
For two rings, enter 10.
For three rings, enter 15.
For four rings, enter 20.
For five rings, enter 25.
For six rings, enter 30 (This is the maximum number of rings/seconds).
