Voicemail not working
Sbarlow69
After muliple times of setting it up my voicemail still wont work
10 REPLIES 10
Dial 1-778-580-4001 and see if you get in to your voicemail.
Try going in to your dialer and dialing ##002# and go. That will reset any call forwarding to the default number for here.Then dial *#67# and let us know what number it came up with.
Some numbers seem to have been re-purposed but the defaulting hasn't figured that out yet. If the default number is a problem one then we can change the number to one that will work.
HI @Sbarlow69  I think it is time to ask CS Agent to help to reset the voicemail for you
 at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
Sbarlow69
No error no nothing
Sbarlow69
People cannot leave a message, therefore no messages to retrieve. Even after setting it up the phon will just ring , Ive followed every step and still no voicemail
@esjliv oops thanks fixed I forgot last letter 🙄
dust2dust
Also, what's not working? People leaving messages? You accessing? Your password?
HI @Sbarlow69   did you get some error message?  or it does not give you the chance to leave a message?
@Sbarlow69  - try restarting your phone, and perform a reset of the network settings. Then hold down the '1' on your phone dialer.
@iliketotalk I think your hyperlink is connected somewhere else🙂
iliketotalk
dust2dust
Try manually dialing 1-778-580-4001 and see if you can get to your voicemail.
