Voicemail isn't working - Line error
DanielJD
Hello,
I've set up a personal greeting. It's stored on the voicemail. When I call my phone number it rings for a long time then gives a beeping and a 'Line Error'. It does not give the option to leave a voicemail.
Can someone please assist? I've just bought a new SIM card, just registered this number within the past 24 hours.
Thanks
@CS_Agent
DanielJD
Hi all,
Android Phone, Samsung Galaxy Edge S7. It's a new number, not ported. Not sure what you mean about multiple greetings. I see they give the option for personal/business/etended leave. I set up the Personal Greeting and want this to be active. But it only gives line busy error.
Meow
Did you use your mobile phone to set up a greeting?
Sometimes setting greeting can be confusing as you have to set up 'real' greeting and 'you reached this-and-this number' from different parts of a system.
Had a hell of a time to remove 'you reached...' message from my vmail but it is possible.
dust2dust
Iphone or Android? Iphone has a new thing called something like live voicemail. Maybe turn it off if on.
will13am
@DanielJD , did you transfer in a phone number from your old provider?  Did you receive notification from your old provider and acknowledge the number transfer?
Hi @DanielJD
wait 5 mins and try again.  Try to call from another phone and test
If same, please submit a ticket with CS Agent here:
