Voicemail Q
pboynett
Me again.  Miss me?
Have one more question.
Is there a way to eliminate having to hear the number a voicemail was sent from before hearing the actual message?  Drives me nuts having to hear it everytime.
Didn't see solution here, but if you knew me you would know that doesn't mean it isn't there.
Peace
Paul
pboynett
Wicked, thanks.  Worked like a charm.
Despite my initial hiccups, this Public Mobile thing really is a refreshing change from you know who....
Thanks
Paul
@bbdata thanks for the info. I learned something new today
bbdata
@pboynettYou acutally can. When you call into your voicemail, go into your voicemail settings. I think the order of the prompts are 4, 4, 2. There are several options you can tweak, including the playing of the caller ID, date and time, etc.
zhadj030
Hello . It's me again as well.
Unfortunately I don't know the answer for this question
Sorry  couldn't help a lot
