11-08-2016 12:14 PM - edited 01-04-2022 01:11 PM
Hi,
My wife and I switched from Rogers double expensive, yet 1/4th data plan to this this awesome deal. Everything looks ok expcet VM.
I wanted to call voice mail, it is not working. I saw a reply for the same question and I tried speed dialing '1', it says ' you haven't set up the voicemail account'. I checked the SIM contacts to see if there are predefined numbers there. There aren't any. I rebooted my phone. Still nothing.
I called my # from another line. Looks like the voicemail is working with the default message. How how to do I call the voicemail?
08-20-2018 10:40 PM
Thank you! this really helped 🙂
03-17-2018 12:39 PM
This does work on iPhone! Just press Voicemail button and it will set you up.
11-08-2016 12:42 PM
Thank you all such a fast response. Calling to my own # worked.
11-08-2016 12:24 PM
hello all, this might help!
11-08-2016 12:24 PM
When I ported my number from Rogers and was all set up, I tried exactly what you did, with the same results. Finally, I tapped the "Voicemail" button on my iPhone -- which caused the PM system to walk me through the process of setting up my voicemail message etc, setting a pin, and so on.
Give that a try - and it would be awesome if you'd post back here to let me know if that worked for you, as this will surely help others as well.
11-08-2016 12:22 PM
I believe you can call your own number from your cellphone and it will go into the voicemail setup.
