07-09-2020 03:50 PM - edited 01-05-2022 12:02 PM
HI,
Just changed my phone over to Public Mobile. I have tried to reset my network but nothing seems to work. Even when I dial 1, nothing happens. I have the 25$ plan.
Can someone help please? My voice mail is important because i'm job seraching at the moment. Thank you!
07-23-2020 04:11 PM
Did you set up your voicemail? Please use this article to do it now.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
Now if you already set it up here's an article on accessing it
Welcome to pm. Stay safe.
07-23-2020 04:04 PM
thanks everyone, I NOW KNOW HOW TO GET MY VOICEMAIL.....
MOCCAGEE3
07-23-2020 04:00 PM
@Moccagee3 dial your phone number
07-23-2020 04:00 PM
@Moccagee3 Hold down the 1 key or call your number from your phone.
07-23-2020 03:57 PM
I CANNOT GET INTO MY VOICEMAIL .... I HAVE A NEW SAMSUNG A10e what do I do to receive my voicemail......
07-09-2020 03:57 PM
thanks for the reply! I figured it out after ...
Have a good one
07-09-2020 03:56 PM
Everything is cool!
You have to dial 1 and then your phone number.
Sorry about that!
07-09-2020 03:55 PM
@jmercho wrote:HI,
@jmercho You will not be able to receive VM until your port completes as VMs will still be going to your previous provider if you are porting your number.
To access Public's voicemail dial 647-580-4001.
07-09-2020 03:54 PM
@jmercho Hi is your phone locked to your previous provider if so you will need to call them to unlock it
07-09-2020 03:52 PM - edited 07-09-2020 03:53 PM
@jmercho hi dial ##004# to reset your voicemail forwarding
you can call your own number to access your voicemail
