Voice Mail
Hollinger
How do I change the number of times the phone rings before the call goes to voice mail?
Couldn't find any setting for this in my phone.
Thanks.
2 REPLIES 2
Hollinger
@softech
Thanks for your reply.
Not using VoLTE.
Get "Call forwarding: Connection problem or invalid MMI code."
@Hollinger this trick might not work anymore as conditional forwarding is broken since the enabling of VoLTE.  However, if you are using VoLTE, it could still work
ope this helps,   Credit goes to @geopublic :
The number of rings is determined by the 'number of seconds to wait' before forwarding the call to your voicemail. Get your PM voicemail number from your Phone Dialer settings.
Dial this sequence: *61 *16475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
  1. For one ring, enter 5.
  2. For two rings, enter 10.
  3. For three rings, enter 15.
  4. For four rings, enter 20.
  5. For five rings, enter 25.
  6. For six rings, enter 30 (This is the maximum number of rings/seconds).
SAMPLE: *61*16475804001*11*20#[SEND or CALL] - sets your phone to ring four times (20 seconds) before going to your voicemail. Best to check mailbox.
