Voice Mail not working
ttumbra44
I have ported over my phone number from Chatr. My number shows on my phone now. I can call out on my phone via Public Mobile but if anyone calls me  they get immediately forwarded to Chatr Voice mail and I cannot access their messages. How do I get my voice mail over to Public Mobile?
Bob
7 REPLIES 7
cellphoneuser1
@ttumbra44
If still not ported, it has failed.  Call Chatr and ask for the account number. Then click on the question mark near the bottom of your screen and type in port request. This will open a ticket to the moderators.
fdrcamb519
@ttumbra44
Welcome to public Mobile for a few hours both numbers will work,  its normal, and will affect voicemail unfortunately, be patient.
ryanrudolf
Bob
the port might not be completed yet. usually takes few hours but might take longer. if its more than several days it will be best to contact a moderator and maybe re-submit the port request.
kselmak
Make sure that you are close to your allternative number if anything goes wrong with the port they will try to contact you.
Until port is done please use your old sim
Welcome to public mobile
geopublic
@ttumbra44  Continue to use your CHTR sim until it stops working. Once that happens then start using your Public sim.
gblackma
@ttumbra44 It sounds like your port is still in progress. It can take up to 3 hours to complete. Keep using your Chatr SIM to receive calls/ texts. Once it stops its done. Then use this article to help you set up your voicemail https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
Welcome to pm. Stay safe.
gpixel
@ttumbra44 how long ago was the port? it takes 2-3 hours for the port to finish.
