04-19-2023 08:16 PM
I can't reach voice mail by clicking the icon on my phone and clicking call voice mail.
I can reach my voice mail by dialling my own number but if I press one and hold it or click the voice mail icon on my iphone, I see a message that my voice mail is calling- but it is not, nothing happens.
Thanks for your help!
04-27-2023 03:36 PM
@GretchenH we are happy as long as your issue is resolved 🙂
04-27-2023 03:20 PM
Thank you for all of your suggestions. The voice mail icon mysteriously started functioning again without a reset. Unfortunately I can't credit any of the approaches suggested as I didn't get a chance to try them. It is an iphone, btw.
04-19-2023 08:43 PM
@softech- How certain are you that it also resets the voicemail access number? The forwarding yes. But the access number?
04-19-2023 08:33 PM
@GretchenH you can also dial ##004# to reset all forward and reset the vm back to the default VM number
04-19-2023 08:26 PM
Can you dial 1-778-580-4001 and see if you get to voicemail? Are you able to make other calls? Maybe try a restart.
Also try dialing
*5005*86*17785804001#
and see if that sets the access number.
04-19-2023 08:24 PM
@GretchenH , is it possible that favorites has replaced speed dial? When I check online, I see these various options.
https://www.idownloadblog.com/2022/04/04/how-to-speed-dial-iphone/
04-19-2023 08:24 PM
What phone do you have?
Usually it is press and '1' on dial. I am not aware on any 'voice mail icon', at least I do not have that on my android
phone
04-19-2023 08:19 PM - edited 04-19-2023 08:20 PM
Is it possible you're out of minutes (if on the $15 plan)?
If not, contact a Customer Support Agent for help.
But first, try calling your number from ANOTHER device, (don't answer it...), then during the recorded message announcement, press the * key, then enter your voicemail password. Can you access it that way?
