VoLTE
Gerry_P
Does anyone know if VoLTE is active in Thunder Bay, Ontario yet?
9 REPLIES 9
Kristowhy
@Gerry_P wrote:
Okay I opened my Network Cell Info Lite app and placed a call. The connection info shows LTE+ Telus Band 2 while the call is active. Previously it would show HSPA during a call which I guess is 3G?
Sounds to me like your VoLTE is working!  Congrats and especially since this is with an overseas Poco X4 Pro!
Hey @softech looks like we have another working VoLTE model for your compatibility thread! 😁
Yes that's the toggle. All good so far. Can you go to the screen mentioned and then make a call and view the screen to see if that line mentioned changes. And also look for mention of IMS registered or not.
Gerry_P
So probably. If your settings menu is anything like mine, as suggested above, can you go into settings, about phone, status information, sim card status - and look for mention of IMS. Then for extra score, make a call and check the Mobile voice network type line to see if it changes.
Gerry_P
Gerry_P
Phone is a POCO X4 Pro. VoLTE is enabled in the mobile settings.
@Gerry_P
If your phone is VoLTE compatible, it will show LTE on the top of your phone but check your Cellular Data Option and enable LTE if it is turned off.
@Gerry_P what phone do you have??
maximum_gato
@Gerry_P
VoLTE is being rolled out in account "bunches" not by location. You need to check by either making a call to see if your mobile voice network type changes to 3G in your Settings>>About Phone>>Sim card status or check if it's provisioned in your "secret" menu on an android phone by dialing  *#*#INFO#*#*.
