Visual Voicemail
Edmonds
Is visual voicemail included in the Canada-US-Mexico plan or is it an addon?
umnikke8
Public does not offer Visual Voicemail, however you can use Live Voicemail, which is very similar, but runs on your phone instead of on the providers network. It requires your phone to be on and connected to function however.
@Edmonds
Live voicemail is built into iPhones, not sure about androids.
Edmonds
I am not sure what Live Voicemail is! Visual voicemail is when you can see all the voicemails on your phone. It translates the message into text so you can read it. You don't need to listen to each vmail to find the one you listen too. I can't believe PM does not have visual vmail. It's pretty standard but usually an add-on.
SKSuh
Live Voicemail (iPhone transcription) works for me — but doesn’t work with hubby’s iPhone + PM
slusagm
PM does not have Visual Voicemail, so, no plan has that at all
