04-16-2019 04:45 PM - edited 01-05-2022 07:13 AM
Hi,I am traveling to London England & would like to if I will able to use my unlocked samsung phone in the uk on pm, if so, what add on plan is best suited for this trip ?
I welcome all experience & advice.
04-16-2019 06:37 PM
@Voices21 a écrit :Hi,I am traveling to London England & would like to if I will able to use my unlocked samsung phone in the uk on pm, if so, what add on plan is best suited for this trip ?
You can have a look at gigsky.com.
04-16-2019 06:28 PM
@Voices21 Check out giffgaff.com as well. You can order a SIM for delivery to Canada for no charge and activate before you leave. https://www.giffgaff.com/orders/affiliate/pds01144
04-16-2019 05:06 PM
Thank you very much. I will definitely look into that company right away.
04-16-2019 05:02 PM
Thank you.
04-16-2019 04:58 PM - edited 04-16-2019 04:59 PM
Unlocked phones from Canada will work fine in the UK. Buy local service which is a lot cheaper than Canada. Try Lebara Mobile. My buddy has had good success with that brand.
04-16-2019 04:55 PM
PM doesn't offer a uk add on so you would have to pick up a local SIM card when you arrive.
