Using esim
icpkdasm
Hello
Im going to be out of Canada in an hour and using esim. I need to active Australia esim.
In that case How can I pause my Canadian esim?
Or Once I active other esim it will be automatically stop it?
Thank you so much
Anerkons
You can include another e-sim and both e-sims would be active.
Anerkons
Just add another-sim. Both numbers will work.
@icpkdasm what you can do is to disable PM eSIM.  Remember, just disable but not delete
When you are back in Canada, disable your travel esim, (you might also go to VPN screen to delete the VPN profile there) .  Next, enable the PM eSIM, then Reset Network Settings
