08-02-2025 01:33 PM
If I get the $30 plan with 20gb that says data for Canada/us, does this mean I can use data in us and not be charged roaming fees or any other fees than my normal monthly subscription?
08-02-2025 01:56 PM
Public Mobile has no traditional "roaming fees". Once your data limit is reached...data just stops working until your next regular plan renewal OR you purchase a US data add-on.
For talk while in US, you must have a newer cell that is VoLTE recognized by Public Mobile as not all are. Here's some info and scroll to bottom of the page to find a VoLTE checker to see if yours is...
08-02-2025 01:53 PM
@Queen1 wrote:If I get the $30 plan with 20gb that says data for Canada/us, does this mean I can use data in us and not be charged roaming fees or any other fees than my normal monthly subscription?
Hey @Queen1
I have one of the $34 50GB Canada US prepaid plans and when I was down in the US, I just went to my Network Settings and turned off automatic and picked T-Mobile. Then I turned on data roaming and rebooted my phone. Once it was back up, I was able to make and take calls, text and use my data. I did a bunch of FaceTime with folks back home in Canada. Wasn't charged a penny for it. The package you want is nice to have for when you go down to the US. No hidden fees or costs. Use it like home. Enjoy your trip.
08-02-2025 01:36 PM - edited 08-02-2025 01:37 PM
Yes @Queen1 you are correct. You can use the data in US as well, no extra charges
But you still need to enable roaming data on your phone for it to work
And you can also call US from Canada and call Canada from US for free
