04-29-2023 08:06 PM
Hello,
I have the 25$ plan with 1Gig of data. We're gonna travel from BC to Montreal and I just wanted to confirm I would be able to use my minutes and data from there without problem.
When checking the details of my plan I see it says "Unlimited Canada-wide Talk" and "Unlimited International Text" so I assume I shouldn't have problems with those. But I can't find details about the data so I was hoping you guys could help me with that.
Thanks,
Martin
04-30-2023 11:38 AM
04-30-2023 08:36 AM
@BKNS27 wrote:
It should be OK but check the PM coverage map and pin point where you are staying
You'd be hard-pressed to find any areas in a radius around Montreal or Ottawa which lack coverage. Telus has strong coverage there, Bell has more coverage, Rogers has full coverage, Videotron has full coverage, even Freedom and Sogetel have many towers in the region. The place has overlapping full coverages.
04-29-2023 08:16 PM
It should be OK but check the PM coverage map and pin point where you are staying:
04-29-2023 08:14 PM
That's great to know, thank you!
04-29-2023 08:09 PM
Your plan will work the same anywhere in Canada.
