Used Phones?
tonyfreake
Can you still buy used phones from Public Mobile? I was just about to buy a couple and now with the change, I don't see that option anymore.
FYI: Previous CPO partner was Orchard; https://www.getorchard.com/
HALIMACS
@tonyfreake
Here’s the direct link to their used phone selection:
https://shop.mobileklinik.ca/collections
@tonyfreake
At the moment, look like PM has removed it and also confirmed by Community Manager.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Public-Mobile-refurb-Phones/m-p/986728#M6...
If you like the PM CPO selection, price and the great warranty, check with your local Mobile Klinik stores or online at https://shop.mobileklinik.ca/ .  Mobile Klinik is also owned by Telus and the prices are pretty much the same, with even bigger selection of CPO phones
@tonyfreake  No the options been removed , but you can still get the for about same price and better. Selection from mobile klinic
