Usage in PM
Shubh2023
Hey yall,
I was wondering if we could see our usage of call/SMS, altogether
Like - 100 mins used, 50 SMS sent - something like this?
Or is there some other way to know all of it? Thanks : )
12 REPLIES 12
Shubh2023
Its fine, gotcha! Thanks : )
hi @Shubh2023 the overview page is that one page summary page.  Won't show sms and mms because they are unlimited
Shubh2023
I got the $40 plan though, so, maybe I cant see it, its cool, thanks y'll
hi @Shubh2023
if you are on $15 or $13 plan, the Overview will show the outbound minutes used lkek 45/100
Shubh2023
Yeah, I was looking for a one-pager thing, where, you can see -- mins used, -- SMS sent, -- MMS sent
I had it back in the other carrier, so, was wondering if they have it here or not!
HALIMACS
@Shubh2023
if you are on the $15 plan with limited outgoing minutes, they will display on your overview screen as “xx/100 minutes”
Shubh2023
Okay, how about calls, like minutes used-wise? Nope?
@Shubh2023
there isn’t a one page summary of all usage, but that is a great idea!
What some users have done is download all the usage to a spreadsheet and then sort it by usage tape.
Albeit, that is a bit of effort to get what you’re looking for.
hi @Shubh2023 sms are unlimited, so, it won't show
Shubh2023
I went there to check, it is showing 1 by 1, I meant, altogether, like I mentioned in the example above!
hi @Shubh2023
login to My Account using browser or app, thr usage info is right at the main page after you login, the overview page
@Shubh2023  In your account main page go to the bottom and check usage history
