07-29-2022 12:05 AM
Hi Community,
I'm wondering if someone is able to have a look at my account and check where all my data go? I checked the usage history and it shows maybe used a 1GB, but my account dashboard shows I have 0 GBs left after 10 days.
Regards,
Kit
07-29-2022 08:40 AM
So you have used it up? What plan do you have the $25 or the $35. You are saying maybe used 1GB but no data available so is it the 35 plan and you think you should still have 2GBs left?
07-29-2022 02:16 AM
Remember to manually reset the data counter on your phone each time your plan renews (when you get notification about plan successfully renewing).
30-day billing cycles are not "monthly" billing cycles, most automatic device-side usage-tracking software will get the numbers wrong (and keep getting worse) after some billing cycles. The usage numbers in Self-Serve are always accurate - as measured on the network-side - more importantly, they're what you're actually paying for.
07-29-2022 12:10 AM
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
to Login Page
or call *611 to data usage.
07-29-2022
12:10 AM
08-08-2022
11:51 AM
Luddite
Found a solution. Used incognito mode in browser and updated data usage.
[seek and ye shall find, eh ............. Luddite]
