Us calling
08-14-2019 01:19 PM - edited 01-05-2022 06:25 AM
08-14-2019 01:50 PM
@jindalzz wrote:If i dont have roaming plan will I receive calls.?
Some users have said sometimes incoming calls are received without a US roaming whilst in the US, but I don't know if that is the case always, or was temporarily the case for a few users.
However, you can receive incoming texts without a roaming plan, but in either case you will not be able to return calls or texts without US roaming add-ons.
08-14-2019 01:40 PM
@jindalzz No you will not receive calls while in the US UNLESS you have US roaming.
Your Canada US calling is for when you are IN CANADA only to make calls to other Canada or USA phone numbers while you are in CANADA.
08-14-2019 01:38 PM
@geopublic is correct again 🙂
I'm ssuming you are on 50 plan, it's just 10 more and you get soo much compared to roaming add-on, which are usually just 10 days.
If you built your plan, so it's between 35 and 50 you'll have to do some math and see what suits you best
08-14-2019 01:28 PM
@jindalzz wrote:If i take canada and us calling in my plan do i need to get any different roaming plan while going to us.?
@jindalzz If you choose the $60 plan that includes data, talk and texting while you are in the US you are covered. Any other plan, you will need to purchase a US roaming add-on to be able to use your device when in the US.
08-14-2019 01:24 PM
08-14-2019 01:22 PM
Public Mobile offers U.S. roaming options for data, text and calling. If you do not have a roaming plan when travellng in the US, you can not use public mobile's services in the USA.
08-14-2019 01:21 PM
@jindalzz, yes you do. The Canada/US calling feature is for use while in Canada only. The roaming add-ons are for use in the US only.
08-14-2019 01:21 PM
You would need roaming to make calls, send texts, or use data.
