07-20-2025 10:42 AM
07-20-2025 11:14 AM
Thanks it turns out when i dialled 611 the auto payment failed.
07-20-2025 10:57 AM
MORE info is needed!
Is your account active? Did you pay the bill? etc.?
07-20-2025 10:53 AM
hi @Yuvna
are you new subscriber unable to get the new account working or existing subscriber lost the service suddenly?
check Telus outage map
https://www.telus.com/en/bc/outages
There is outage in Surrey, BC as well as some part of Edmonton, are you there?
Also, login My Account and check if account is active. Reboot the phone and Reset network settings.
If still does not work, try the PM sim on another phone
Last, ask PM support agent to check, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
07-20-2025 10:49 AM
log in to your account to verify if your regular renewal failed. You can also dial 611 to hear your current plan status. You'll be able to make payment using your on file payment card...but you'll need to know your PM pin number to do so.
