Upgrade
CBuchanan
I upgraded back in Oct 25? From 3G to 4G and STILL has not changed? I’m being charged 4G but still on 3G? So can you please help me with this and put through my up grade , thank you.
8 REPLIES 8
@CBuchanan wrote:
I have tried what you suggested and also turned iPhone off and on again , the only things I can switch to is either 3G and LTE , there is no 4G ….my phone is the IPhone XR ..I read that LTE is a half way point between 3 and 4G?  But still not a solid 4G?
@CBuchanan  If you want the best available speed having purchased a 4G plan set your Cellular Data Options for Voice & Data to LTE.
@CBuchanan
LTE=4g. it's best to look at the term interchangeable. you'll only confuse yourself. you need to contact customer support
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
CSA are available from
- Monday to Friday: 6AM- 10PM EST
- Saturday and Sunday: 6AM- 10PM EST
CBuchanan
gpixel
@CBuchanan
what version of iPhone? is the preferred network set to 3g/wcdma?
@CBuchanan   check and change the network to 4G
Open “Settings.”
Tap “Cellular.”
Choose “Cellular Data Options.”
Pick “Voice & Data.”
Make sure 4G is selected
CBuchanan
My account shows 4G but in the corner of my iPhone it still show 3G??
Kristowhy
How do you know you are still on "3G"?  Have you conducted a speed test?  Does your plan show up as the 4G plan in your PM account?  Did you upgrade right away or set it to upgrade when the plan renews?
Remember that the only difference between "3G" and "4G" plans are the LTE data speeds with up to 3Mbps up/down and up to 100Mbps up/down respectively.
@CBuchanan First, login My Account using Incognito mode, it should show clearly that your current plan is one of the 4G plan
Then on your phone, check your Preferred Network type, make sure it has LTE or 4G selected
Then you can try a speed test using the app , like
https://www.speedtest.net/apps/android
https://www.speedtest.net/apps/ios
