Upgrade promo not appearing on my account
11-28-2022 11:52 AM
I got this text and when i click it i do not see it under my account. What do i do? Please help. Thanks
Public Mobile here.
Save this Cyber Monday on our 4G speed plans! Upgrade to 15GB of 4G speed data for just $40/mo. Get this deal in My Account at https://myaccount.publicmobile.ca. Plus, refer-a-friend and you'll both receive $5 off your bill for the next 5 months! Conditions apply.
Rewards
12-01-2022 10:00 AM
self solution removed
12-01-2022 09:50 AM
Thank you all for your help. I think i was able to get it
11-28-2022 11:49 PM
I don't believe that plan is offered anymore...
$45/20gb & $35/20gb($20 credit for 15 months) are the available promos
11-28-2022 11:57 AM
@malams hi in your change plan section use the scroll down arrow and you will see the offer 😁
11-28-2022 11:55 AM - edited 11-28-2022 11:56 AM
When you do a plan change @malams , it is usually set to your next renewal.
In order to see it pending, (or set one up) when you log on to self-serve, click the little refresher icons, then go under the tab "plans and add ons" on the left for any pending plan changes.
