Phone Compatibility
cmariel
1. Is the Google Pixel 7 Pro compatible with Public Mobile 4G plans?
2. I can't get a clear answer online as to whether 5G phones can use 4G plans.  On the box of Google Pixel 7 Pro box, it says the phone must be on a 5G network, but that seems not right to me.
Thoughts?
yardbirder
Congrats on getting a Pixel 7 Pro, I bought one in October and it is awesome! I've had no trouble at all using Public Mobile with it, it was fairly seamless transferring to the new phone from my Pixel 2. Have to say I've spent a fair amount of time on youtube watching videos on how to set up and use all the features.
cmariel
Thank you for sharing!! I appreciate that.  I couldn't find anything on the Public Mobile site.
cmariel
Thank you!
@cmariel   you are lucky, with a Google Pixie, you can go to any provider in Canada without worry about compatibility
HALIMACS
Yes, it's compatible @cmariel
Here's a broader description, select the "expand" downward arrow in the Network line and see what frequencies it supports:
Google Pixel 7 - Full phone specifications (gsmarena.com)
