Unsubscribing
treefrog
Now that I have been switched to the points program and there is no monetary incentive to subscribe to autopay if I unsubscribe with a balance in my account that is more than my plan amount will my plan still renew? To suspend my account is my only option to use lost/stolen? Thx
Edit: BTW....I still can't reply so I can only edit this post if needed.
@Handy1
The only option then which means I can't recieve 2FA codes on my personal phone on my next work assignment.
@hTideGnow
I've done both in the past so I am well aware that using lost/stolen immediately suspends your services. I just wanted to know if "unsubscribing" completely prevented renewal from occurring. But judging from. @Handy1 's answer it does not it just stops autopay.
2 REPLIES 2
HI @treefrog
you can still disable Autopay to suspend your account at the end of the current cycle.
If you suspend your account using Lost/Stolen, it will be suspended immediately, do you want that?
@treefrog  Yes if you have available funds in account it will try and take those funds automatically. So reporting lost stolen would  be an option .
