12-25-2020 11:01 AM - edited 01-05-2022 04:36 PM
I have an old locked iPhone 6 and I can't activate my new Public Mobile SIM card b/c the phone is locked... Help? Thanks!
Phones
12-26-2020 11:45 AM
Thank you! I used to be with Rogers, years ago - I called them and they unlocked it instantly (through apple as you said). Thanks!!
12-25-2020 11:44 AM
@LRosevear wrote:I have an old locked iPhone 6 and I can't activate my new Public Mobile SIM card b/c the phone is locked... Help? Thanks!
Since you have an iPhone you do not need a code. You have to find what carrier the phone was purchased from. Then contact the carrier and they will send a request to Apple to unlock it. Some carriers are no longer cooperating and require for you to have service with them for 90 days before unlocking. Do you know the carrier? Was there an old SIM in the phone? Or try imei here https://imei24.com/check/iphone_lock_checker/ It may tell you the lock status or what carrier it is on.
12-25-2020 11:09 AM
@LRosevear , phone unlock codes are supplied through the carrier that sold the device in accordance with section F of the wireless code.
12-25-2020 11:04 AM
Get the code from the previous carrier
