03-28-2026 08:16 PM - last edited on 03-29-2026 09:22 AM by Silvio_M
After applying and paying, I needed to log in to the Public Mobile app and apply for a number change. However, after logging in, there's been no screen. Can you help me with this?
***Message edited by CSA_PM to comply with the Community terms of service.
03-29-2026 09:24 AM
@ Lyndon3 Hi,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
03-28-2026 08:22 PM
Please remove the email, we are just customers
So, what phone do you have?
You can try to uninstall and we install the PM app and test if it works
If you still get the blank screen, you will have to ask PM to help you to complete the activation
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
03-28-2026 08:19 PM
shut down then reboot your cell; then log in to your new Public Mobile account.
