10-26-2024
01:03 PM
10-26-2024
05:07 PM
computergeek541
Have read and tried all suggestions on how to manually update the APN settings but still cannot send photos or group texts. My phone is a Blu F91 5G with Android 11.
10-26-2024 03:26 PM
Yes have already tried that as well.
10-26-2024 03:06 PM
hi @PP11954 did you try Google Message? if you already have it , uninstall and reinstall
10-26-2024 03:06 PM
maybe time to ask PM to check your account
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
10-26-2024 02:59 PM
Have tried using all capitols as well.
10-26-2024 02:47 PM - edited 10-26-2024 02:47 PM
what change you referred? did you update the APN settings as said by @hTideGnow @? The APN name might need to be all CAP
10-26-2024 02:32 PM
I should note it did work fine until Public Mobile changes made earlier this year.
10-26-2024 02:30 PM
Google messages is the default app.
10-26-2024 02:29 PM
Have done all these steps. Still can't send group message replies or photos. Receiving them is not a problem.
10-26-2024 01:09 PM
Blu F91 5G does not have all the required bands PM has. It might still work but the connection won't be great.
try using Google Message to send and receive SMS/MMS
10-26-2024 01:05 PM
hi @PP11954
sms/mms every work on this phone? and data works well?
start with the easy fix, make sure mobile data is turned on and try Reset All Networks
if same, please update the APN, the following entries have to be correct
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
