Unable to receive texts unless on Wi-Fi
Flores
I've gone through all the community threads, but cannot resolve this issue.
I've used my Moto G5 without a problem on public mobile for over a year.
I cannot receive sms texts if I am not on wifi.  I am using the Google sms text app and had the same problem when I switched to a different sms app. ( Textra)
Network reset, APN settings are correct, have suspended service and restarted service, mobile data is on, roaming on and off ( no change).  I also did that thing where I chose a different phone provider and then re-chose Public mobile
My phone still works for calls.
Any ideas on how to help?
rhbcc
maybe try this and try to tinker with your settings:
Settings > Data Usage > Cellular Data (some phones may say Mobile Data).
Another may be Settings > More > Cellular Data
HI @Flores ,
If your Chat Features are on, turn them off.
Disable your Chat Features:
  1. Open Messages
  2. Tap More options > Settings > Chat features
  3. Turn Enable chat features off
dlambro
@Flores
Hi, I found this article from The Droid Guy, it may help.
www.thedroidguy.com/cannot-send-receive-messages-motorola-moto-g5-easy-steps-1080782
Look at the 3rd solution, to clear app cache and data.
RosieR
Hi @Flores according to this article Can’t Receive Text Messages on Moto G
If you have service on your Moto G but can’t receive text messages, the only way to fix this issue is by performing a factory reset
I hope this helps
RosieR
This isn't a Public Mobile issues. SMS text messaging does not use an internet connection of any kind. Do you have an RCS setting enabled?  Try turning that off.
