03-21-2019 01:42 PM - edited 01-05-2022 03:51 AM
All other services seem to work except receiving phonecalls - when calling my number it goes automatically to my previous Rogers voicemail. Data, text messages and outgoing calls are no problem at all. I'm on a Samsung S8. I've turned off the phone and removed the Sim card several times to no avail.
Joining Public
06-07-2019 03:55 PM
When i ported my number from Rogers tobpublic mobile it took me about 5 to 6 hours before i could do anything i couldn't even send or receive text messages
03-21-2019 09:48 PM
Thanx a bunch. 🙂
03-21-2019 04:38 PM
Hello, @duffer900!
It takes from minimum 30 minutes to maximum 2 hours and 30 minutes for the port to be complete.
03-21-2019 03:14 PM
Happy it is working for you. Just curious for information sakes, how long did it take from the time you requested the port, to the time it was completed?
Thanks
03-21-2019 02:28 PM
I just received a text saying the port process is complete and can now receive calls! Many thanks to both of you who responded to help.
03-21-2019 01:54 PM
I switched/ported yesterday morning...so it should be working by now. Thanks - will contact a mod.
03-21-2019 01:50 PM
From my research this doesn't seem like it is supposed to be happening.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Porting-Number/m-p/90534#M16461
How long ago did you submit the request to port? It may be an error with the porting process. Your Rogers sim card should still be working. Don't cancel it until one of the mods has looked into it.
03-21-2019 01:49 PM
@jama_g wrote:All other services seem to work except receiving phonecalls - when calling my number it goes automatically to my previous Rogers voicemail. Data, text messages and outgoing calls are no problem at all. I'm on a Samsung S8. I've turned off the phone and removed the Sim card several times to no avail.
This is normal as porting from Rogers usually take a few hours to complete. PM assigned your number to the account right away for outgoing call or message, but incoming call has to wait for Rogers to fully release your number.
