06-25-2025 09:18 PM
Hello, injust sighed up today I did not know that an email was sent from mybprevious provider until it was expired, asking g me to confirm the transfer of my number. Not sure this is what the issue is? However I can't recive calls or texts. I am.able to call out.
06-25-2025 09:40 PM
hi @Jennj
just call the number I sent you and see
if the calling does not work, you can submit ticket by direct message:
06-25-2025 09:37 PM
Hello,
I did not get a text as I can't recieve calls or texts
I did later see I had an email but it was passes the 90 min time frame.
06-25-2025 09:27 PM
hi @Jennj
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
