Unable to make payment
Seefoisy
Hi,
I've been trying to make a payment to my account. I keep getting the same message saying my card is declined. I've tried different cards. I even tried my husband's card. Nothing is working. What should I do. I tried everything.
Christina
2 REPLIES 2
darlicious
@Seefoisy
You may have fraud locked your account by trying too many times. Have a read thru the spoiler below and give it another go after an hour. If you have no joy then contact customer support to remove the fraud lock. You might as well save yourself any more grief and just get the CSA to add your payment info.
Spoiler
I just click on one time payment and in the middle of the page you can click on manage my card. Then I follow this procedure....
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
  1. Reboot your device.
  2. Clear your browser, use secret/incognito mode in firefox, chrome or safari.
  3. Choose replace card rather than remove card.
  4. Copy your address from your billing statement.
  5. Add your apt/unit/suite # to the street address. ie. 101-123 1ST AVE W, CITY, PROV.
  6. Do not put a space in the postal code. X0X0X0 not X0X 0X0.
  7. USE ALL CAPS if necessary.
  8. Do not use autofill. Type everything manually.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from customer support.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active  click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot.
@Seefoisy
Too many failed attempts may temporarily lock your card with Public Mobile. So wait over 1 hour before you try again.
When you do try again clear your browser's cache, or try a different browser or device.
Opening a tab in incognito mode may help as well.
Ensure the address you are entering matches the billing address with the card company, use all caps in the postal code with no spaces, and if there is a unit/suite number leave that blank.
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
