Unable to login to my account
RonnieV
I keep getting told I am locked out. The first time I attempted to login I was told I tried too many times and I was locked out for an hour. I waited and tried again and same thing. I tried the forgot email and forgot password but it doesn’t work , almost like an endless loop. We were trying to add optional roaming but can’t access valid account. Any tips
2 REPLIES 2
RonnieV
Thanks softech. It
Thanks Softech, when I switched to incognito I was able to login. I tried the app after that and it worked as well. Thanks to your quick response I was able to set up our roaming coverage before we leave tomorrow. Greatly appreciated. RonnieV
@RonnieV did you try using the app??
or ues Incognito mode to reset password and use the same  incognitive mode to login
if same, Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
