12-27-2023 05:44 PM
I am getting a forbidden A1 and sometimes an unauthorized when trying to enter the self serve portal.
I recently just signed up and need to port my number over.
12-27-2023 06:24 PM
@uberism I think, but am not certain, that you cannot re-use an email address once you have closed the account that was set up with it. Someone with more knowledge can maybe confirm or refute that. At this point your best bet is probably to send customer support a private message using the link I posted earlier in the thread.
12-27-2023 06:22 PM
Then how would i access my new account?
12-27-2023 06:13 PM
yes, the same email was used
12-27-2023 06:13 PM - edited 12-27-2023 06:13 PM
@uberism Did you try to use the same email address you had before? Also if you ported out then your PM account is closed.
12-27-2023 06:10 PM
Dobut thats the issue. I've been trying all day and doesn't seem like its affecting anyone else
I think it has to do with how i transferred a line out of public mobile and then signed up a new one right after.
12-27-2023 06:06 PM
Hi @uberism
Because Public Mobile announced a whole wack of new plans today, the website will suffer. Just keep trying and you'll get there.
12-27-2023 06:06 PM
@uberism You can contact customer support via this link
An agent will reply to your inbox in this community, watch the envelope icon top right or if no envelope them tap your avatar and check Messages.
12-27-2023 05:57 PM
App isn't working. I log in and it redirects me back to the log in page. There is something wrong with the backend that is blocking me from accessing my account
12-27-2023 05:50 PM
try the app if the website isn’t working, or vice versa
