03-22-2023 03:43 PM - last edited on 09-22-2023 09:26 AM by computergeek541
I'm unable to log in to me account anymore (password and/or email address rejected). Resetting password also does not work. Requested a security code to both email address and phone number and it is never sent (did not end up in junk folder either).
09-22-2023 09:16 AM
I am having the same issue I cannot believe this! I had to reset the password although I know it was right... I ended up going thru text (phone then web) to reset it, because validating my email did nothing.
03-22-2023 03:58 PM
Hi @ericembacher then should be good. You can try turn off the phone for 5 mins and test according to PM help post earlier
03-22-2023 03:55 PM
No...payment went through, no chargeback.
03-22-2023 03:54 PM
Hi @ericembacher you didn't make any chargeback on any PM charges with your credit card? if you didn't do it, PM should be able to help
03-22-2023 03:52 PM
My last payment was processed just a couple days ago. I have submitted a ticket, thanks.
03-22-2023 03:45 PM
Hi @ericembacher when was the last time you paid for the service? when was the last time you can use the service? The phone shows connected?
Try submit ticket with PM CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
