Unable to log in to self serve
Lynnetompkins
Try to reset pass word won't le me. Can't get into account.
PAULRANG18
Refresh the page and try again after a reasonable period. Websites correct themselves. Contact moderator if issue persists by clicking ?, bottom right, and follow instructions.
redgam8
Can you specify which part you are having trouble with?
popping
Your account will be locked if your had tried too many failed login.
You can wait for an hour and try again OR
Create a moderator support ticket using the ? button at the right side bottom corner of this page.
Keep asking SIMon to "contact human" for one or more times. SIMon will eventually show you the "Submit a ticket" button. Click on submit button to get the create ticket screen.
Moderator wait time is up to 2 days.
Triguy
Try using a different browser and incognito mode.  Clear your cache and cookes then reboot.  If you still have problems then submit a ticket by clicking on the question mark on the bottom right.
