04-13-2025 07:47 PM
Hello,
I tried to change my subscription plan on renewal, but the system seems to be stuck on "loading" , thus not completing the request for a change.
What can I do?
Thank you
04-14-2025 02:01 PM
Thank you. I will try doing that.
04-13-2025 10:50 PM
@redmapleleaf of course you can contact agent
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
04-13-2025 10:21 PM
Thank you for the reply. I don't have the app on my android phone, because it is an old model and is not compatible with it; And I am not able to open a ticket either. Is there another way I could chat with a support agent?
04-13-2025 10:20 PM
Thank you for the reply. I don't have the app on my android phone, because it is an old model and is not compatible with it; I am using my laptop. And I am not able to open a ticket either. Is there another way I could chat with a support agent?
04-13-2025 08:17 PM
@redmapleleaf wrote:Hello,
What can I do?
Thank you
If it's an Android phone, go into the app settings and clear the cache and the data. Then sign back in again and try again. If it's an Apple, delete the app and redownload it. If it's still causing you issues, create a ticket for a CDS Agent to resolve.
You can create a ticket and ask a CS Agent to fix it.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
04-13-2025 08:16 PM
@redmapleleaf do you have another device to use?
First before you sign on, clear cache and refresh the page.
