Unable to activate the call forwarding
guberm
Hello,
I'm trying to activate the call forwarding by *004*xxxxxxxxxxxxxxxx# and getting the error "Call forwarding MODEM_ERR".
Does anyone have idea?
9 REPLIES 9
@guberm
Pixel 7 is VoLTE compatible here.
A member said before that if VoLTE is used, support can manually fixed the Conditional forwarding issue.  Engage them by direct message using the link below, and let us know if they can fix your issue:
guberm
I'm using Pixel 7 Pro with Android 14, and LTE icon is displaying, last few weeks shows 5G icon
@guberm
Conditional call forwarding has been broken since the introduction of VoLTE.
But what model of the phone do you have?  Were you actually using VoLTE when you were making calls?  So, if VoLTE is enabled, when you make calls, does the phone showing LTE or 4G still and not dropped to 3G?
if you are using VoLTE for voice calls, there is a chance that support can fix the call forwarding problem
guberm
The same behavior with VoLTE disabled ☹️
guberm
Yes, Canadian number. Yes, VoLTE is enabled
Are you trying to forward to a Canadian number? Has the phone been enabled for volte yet? If you're using volte then we know of another user that asked support to fix call forwarding.
guberm
I tried this also, and in this case getting the error: "Call settings error.
Unexpected response from network."
guberm
It's different type of CF, I need a "Variable" option. You can scroll down to see
guberm
I'm using Pixel 7 Pro with Android 14. I didn't use CF before in PM
