Unable to Activate Subscription
NTHlucky
I cannot finish the activation of my subscription. I’m on the last step 6/6 and it says subscription not activated, but I already paid. The PM app is now suddenly under maintenance and I can't do anything right now. Chatbot is not useful at all and Im also unable to create a ticket. It's impossible to get a hold of a customer service agent.
FKozlik
This did not work for me.
Useful tips.  thanks @NTHlucky
NTHlucky
Hi guyssss, for those who are experiencing issue activating subscription (stuck on last step 6/6), the fix is simply just RESTART YOUR PHONE. Please try it out. It worked for me. It might not work 100% but its worth a try. Just wanted to help everyone here.
NTHlucky
OMG. Restarting the phone is THE SOLUTION. I got my subscription activated and esim working now. Thank you so muchhhhh!!!
hi @NTHlucky
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
if not, ask PM support agent to help, you can submit  ticket by direct message:
