04-01-2024 10:40 AM - last edited on 04-01-2024 05:23 PM by computergeek541
I'm going to Los Angeles next week. I have a free calling to the US plan. Will my phone work there? Will there be roaming charges?
04-01-2024 01:26 PM - edited 04-01-2024 01:31 PM
To turn on roaming:
On an iPhone go to Settings > Cellular > Cellular Data Options
On Android, go to Settings > Network & Internet
or swipe down from top of any screen and select Network > then find settings (gear) button beside the network name.
I just returned from LA a few days ago. With the new PM CAN-US wide voice and data plan, everything works great. You won't get roaming charges. Note that you also need to select T-Mobile or AT&T or else it won't work (don't use Verizon). On an Android phone, deselect Automatic Network and select T-Mobile. That seemed to work better than AT&T in the LA area for both my Android and my wife's iPhone. On the iPhone it's Settings > Cellular > Network Selection.
04-01-2024 01:23 PM
@Leroy7496 VoLTE is Voice over LTE which is needed in the USA because they do not have 3G networks any more. Canada still uses 3G so a phone may work fine here but not in the USA. You can check the Public Mobile VoLTE list to see if your phone is on it, although some will have VoLTE that are not explicitly mentioned.
https://www.publicmobile.ca/en/on/get-help/articles/volte
You may or may not have a toggle for VoLTE in the phone settings but it would still depend on whether the phone is enabled by Public Mobile even if toggled on. Data and texting should still work regardless.
04-01-2024 11:58 AM
Turn on Voice on LTE (4G) if you phone have this feature in you cellular Voice &. Data settings.
04-01-2024 11:55 AM
If the free USA calling was the More is Merrier bonus promo. You can only make calls to the US while in Canada.
No you won’t be charged for roaming. Your phone can only receive text. No service in the USA unless you purchase a Roaming bundle Add-on.
Or you can use WhatsApp or TextNow app for free calling and texting in any free wifi.
04-01-2024 11:00 AM
what make / model is your cellphone ? Go in to your settings to enable Roaming...but let us know which phone you use for exact directions. PM has enabled volte in some..but not all phones. The volte is best option for use while in US.
04-01-2024 10:59 AM
hi @Leroy7496 what phone do you have? if you have the compatible phone with PM network, it is VoLTE enabled already and you don't need to do anything. If it is not, then you will have to use T-Mobile 2G network for voice
04-01-2024 10:58 AM
What is a volte enabled phone? How do I turn on roaming?
04-01-2024 10:44 AM
HI @Leroy7496
your phone should work for data, but voice is a maybe, what phone do you have?
to have roaming, you need to have a roaming add-on unless you already have Canada-US plan. And make sure you turn on mobile roaming on your phone and manually connect to T-Mobile or AT&T
04-01-2024 10:44 AM
@Leroy7496 What plan do you have? You need a Canada-US plan or add-on for the phone to work in the USA. If by "free calling to the US plan" you mean you have is a US long distance calling minutes add-on then no it won't, it's just for calling to the US from within Canada.
04-01-2024 10:41 AM - edited 04-01-2024 10:42 AM
if you have a Cdn/US plan you;'re good to go. Make suire you have a volte enabled phone for best talk-ability in US. Also, enabled Roaming Data in your settings. You won't have any surprise bills anytime with PM.
sp
