07-19-2024
12:28 PM
07-19-2024
01:47 PM
computergeek541
Does this plan mean I won't get roaming charges when I go to the states from Canada? Xan I use my phone normally?
07-19-2024 07:25 PM - edited 07-20-2024 12:14 AM
@Yea123: Please remember that the quality of the message posts matter. Please avoid repeating others.
07-19-2024 12:32 PM
@Taiano1 , that is the CAN-US plan that allows you to use your phone in the US as if you were still in Canada. Be mindful that if your phone is not VoLTE compliant, phone calls while in the US might be very challenging if not impossible. There is no longer a 3G network in the US and T-Mobile 2G is almost non existent. What model of phone do you have?
07-19-2024 12:31 PM
The Canada/USA plan will work in both countries without the need for purchasing Roaming Add-on…it is all included…calling, texting and data.
